Mark Henderson
Today I finished the aft bulkhead but did not have time to try fitting it. I did use a dial caliper to measure to get an idea as to what combination of washers to use. The bearing is .570" and the bracket is .656". This gives me a .086 "gap. The AN960-416L washers are .032" thick. In theory at least if I use one on each side of the bearing I will have .022" of slop. Is this acceptable? The only other option is to use a AN960-416 and a AN960-416L which total .095" . Which is the better combination? Thanks
