Just figured I'd post this here, as I found nothing on it while searching.
Ditched my internally regulated denso alternator after the second one failed, possibly because of the hammering it takes from my EarthX battery.
Anyway, went with the externally regulated B&C L-40. The boss mount bracket B&C provides is nowhere close to fitting with the snorkel. Looks like a lot of guys just modify the fiberglass snorkel, but I just modified the bracket.
Re-drilling the bracket as shown gives you a good fit, using a 7350 belt. You'll need to trim the ears on the bracket as needed to fit. I didn't get a "before" shot, but the stock bracket is quite a bit taller.
