Phil
I'm adding rudder trim similar to Vic's and I'm planning on using Avery's fairings for the pushrod exit.
Instead of putting the fairing on the outside of the skin, I'd like to put it on the inside. This means I would cut an exit hole for the fairing to protrude though.
This might be how they were intended, but I've seen them on the outside too and I'd rather have them on the inside and use a filler to fill the gaps around the fairing and hole.
Has anyone seen them done this way? How'd they turn out?
