nothing special. it was an easy job.
check brake pad wear, lowest measurement was at the corner of the inner pad, .110. limit .10, so I was almost there.
no need to remove the wheel or open the brake line for brake pad check or replacement if brake line can flex.
ok, while at it, removed the wheel for bearing grease.
pack bearing
flight checked good. an easy job. brake pads, $33 total. can't beat the price.
![IMG_20160704_124326.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-PQLjv4CGhM8%2FV3x1liX24EI%2FAAAAAAAARYQ%2FeYbzEFzwtJIkalXBQmaal521QxIsi8DGQ%2Fw530-h707-p-rw%2FIMG_20160704_124326.jpg&hash=a08b66915932083b41ac096ecd895896)
![IMG_20160704_124536.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-KvLR4jB1AHc%2FV3x1pT2-mSI%2FAAAAAAAARYg%2Facg_rKKvqgErCOVQcAxy7kY9R-9dAVa8Q%2Fw530-h707-p-rw%2FIMG_20160704_124536.jpg&hash=e77aceea1cf8031a2ae42ac99de13fd9)
![IMG_20160704_133121.jpg](/proxy.php?image=https%3A%2F%2Flh3.googleusercontent.com%2F-63iC56vfI_8%2FV3x1wd2aaVI%2FAAAAAAAARYw%2F1GwgNSydER4mv0jnxQv2DlFFDomk-KiJQ%2Fw530-h707-p-rw%2FIMG_20160704_133121.jpg&hash=aa629850f6b489a618aaed9bbb1bda2c)
pack bearing
