I have about 12 hours into the HS thus far. I've spent at least twice that time on the learning-what-i'm-about-to-do steps. Fluting is one of those seems easy processes, but I just can't get my head around it, and I spent 20 mins on each part. I've had a few ah-ha moments though, so hopefully that'll get better.
I did make a mistake in drilling the main rib (HS405) to to front spar (HS702) to angle reinforcements (HS710 & HS714) to leading rib (HS404) section. I used the nifty angle-drill from Avery tools, which seems to work great. However I managed to let it walk around a little bit while drilling, and got the following few bad holes, including one that went through to the spar.
Is this salvageable? I will call Vans and ask, i'm just trying to get a feel for how bad mistakes like this really are. Can i drill out and bolt?
