DragonflyAero
As requested, here are a few pictures.
RV-7 N321BV made its maiden flight today. The flying characteristics were flawless. The Dynon Skyview system worked perfectly I have a new engine so need to do the run-in over the first few hours and used the autopilot which allowed me to closely monitor all engine readings as I made racetracks on the sky over the airport. The only problem noted was some roughness from the E/I. The mag side ran smooth as silk.
On return I removed the cowling a found a few fittings I needed to snug up before the next flight. I also contacted Electro Air and they provided suggestions on how to correct for the E/I roughness.
Another RV takes to the air!!
This site have been a huge help over the course of my build. Thanks to everyone!!!
