Neal@F14
Paul Bonner and John Hooker's RV-10, N678BH, made its maiden flight Friday morning, July 3rd 2009!
I'll try to get some pictures online later.
A couple of issues with erratic readings from the Dynon D120 EMS tach and manifold pressure gauges were easily fixed by changing resistor values for the p-lead connections that feed the Dynon's tach inputs, and inserting a flow restriction device into the vacuum hose for the MAP sensor.
Another major squawk discovered is that the center console-mounted throttle quadrant was a bad idea. It sure looked pretty, but the console is simply just too wide, and you cannot get full stick aileron deflection with your leg in between the stick and the console, unless you have skinny toothpick legs like Olive Oyl, so the fiberglass console around the throttle quadrant is getting ripped out, and the quadrant relocated upward a few inches to immediately below the instrument panel to make some legroom.
