RV-7 C-GCPD took to the air last Thursday June 12 from CNM4 in Ontario.(Stratford Ontario) following a 4 1/2 month paint job and a lost paper work issue (on their end, not mine) Flew great except for one thing..a high oil temperature. My check pilot and myself elected to land after only .2 in the air. We took off under full power and climbed out to 4 thousand feet ASL. We pulled power back to 25 square during the climb however the oil rose to 230 F and was on it's way to 240 F when we pulled power and came back down. The engine is a newbuild 10-360 with 9.25 pistons. The prop is a Hatzell blended airfoil. The cooler is a standard Van's unit, an 8 tube Niagara Thermal as suppled in the FWF kit and is mounted in the recommended position on the back of the bafffle of Cyl #4. On Saturday I pulled the oil temp sensor (Dynon supplied for the EMS-120) and tested it using the boiling water test and the displayed temp seemed to be OK. The on-field mechanic came over and checked out my instlation and he says it should be fine. He believes the cooler is big enough and should be getting plenty of air.
During my short flight the cylinder head temps seemed to be OK and did not reach redline. The EGT did not redline either.
Do I go for it again but reduce power to 24 square rather than 25 square? Use a much more shallow climb out and stay lower to allow more air through the cooler?
What do you guys think is the absolute highest sustained oil temperature I can maintain while my expensive engine breaks-in?
It's a beautiful day to fly here today, but I don't want to cook my engine .
Dave
Dave
