I prepared for engine start today and I had some problems.
1. I have an IO 360 Superior engine. I activated the boost pump to prime the engine and tried starting the engine. I was getting popping and loud noises. I stopped the engine. I tried it again and still got popping noises.
I got out of the plane and found oil under the left exhaust pipe. The engine was pickled and before I installed the spark plugs I let the oil drain from the cylinders for a couple of days but apparantly oil was still in the cylinders. I do not know if that caused the popping or if it was too much fuel. I waited awhile and tried it again. I pulled the mixture back all the way this time, pushed it in some when started and and it went smoother. I opened the mixture up some and it finally started to idle better. I will be honest, it scared the c*** out of me!
I would like some opinions on what I did wrong and how to improve my technique.
2. Oil was throwing over the plane (cowl off). It seems to be the oil filter not tight enough. How do you all torque the oil filter to specs when you cannot get an wrence between it and the firewall????
3. I also had some problems with my Dynon EMS. The MAP pressure shows 61.4 all the time & The amps show -99 all the time, engine off or on. What gives with that?
At least it started.
