What is the consensus of the group on which sealant to use between the skins and the firewall? I have read the sticky on this topic, but am more confused than before. Is the 3M Fire Barrier OK for this? Will it work for well for the other sealing that needs to be done? I really like the idea of being able to run down to Home Depot for the stuff.
Also, what would you recommend for sound/heat barrier material under the sub floor & sides? I don't mind cutting pieces to fit, but would really like to avoid anything that requires mixing & spraying if at all possible.
Thanks in advance!
Shannon Hicks
Thanks in advance!
Shannon Hicks
