rv9aviator
In the directions it says to leave out the firewall recess until later to make it easier to install the rudder pedal brace and other inside stuff. Earlier in the directions is says you can either mount the flanges of the recess on the forward side of the firewall or in between the stiffeners and the firewall for a cleaner look. I opted for between the stiffeners and now don't see how I am going to assemble the firewall without riveting the recess in at the same time which will make it tough to install the rudder brace. I did a search but didn't come up with anything.
I guess I will also have to finally decide on an interior color since the braces on the firewall will have to be primed and painted if I want them to match everything else.
