I have several questions that i have searched for answers in the archives and have not found what i want to know. I am building an RV8 with the 0360-A1A carbed engine and CS prop. I do not have my firewall forward kit or drawing #60 yet. I would like to know if those of you that followed the plans are happy with the called out throttle,prop,mixture penetration locations shown on drawing #21. And also would like to know if the specified vernier cable lengths worked out well. I am going to order and install these shortly. The only thing i am doing different from the plans is that i used the deluxe throttle quadrant and moved it inboard and aft 1/2" which i cannot see making much difference. Second question since i do not have drawing #60 can someone tell me where vans shows the fuel line penetrating the firewall and did this location work out conveiniently for the routing to the engine driven mech fuel pump. I am not going to put the gascolator there, i will simply install a bulkhead fitting there as my gascolator and elec boost pump will be in the left wing root. Last question, I saw on one post that vans now prepunches the firewall for these items and the cabin heat inlet. I am curious to know where the cabin heat penetration is if someone can tell me that. Thanks, Tony
