macrafic
I'm wanting to create my firewall penetrations for the fuel line and throttle. RV-7A IO-360. The plans locations are really tight anyway but, given that I am wanting to use a ball connector for the throttle, there simply is not enough room.
The picture below shows my adjustment of each, along with the original plans location. Basically, I am wanting to lower the fuel penetration 1 1/8" and raise the throttle penetration 1".
As you can see from the picture, this appears to give me plenty of clearance from each other, from the starter contactor, from the engine mount, from the heater bypass box and from the nose gear access hole. It also still leaves the penetrations within the fuel pump housing, where it should be. I have the Andair fuel pump, so do not need the space on the firewall for a pump.
Anybody see anything I am missing? Comments on good/bad practice?
![xd8cwg.jpg](/proxy.php?image=http%3A%2F%2Fi63.tinypic.com%2Fxd8cwg.jpg&hash=5f3afe504ba9872535a4833794d2f41b)
