For throttle and mixture I would (and am) using these
https://www.aircraftspruce.ca/catalog/appages/eyeballfw1.php?clickkey=32868
The ball allows the cable to find its natural angle. The ones you are considering will not.
Thanks, what size hole do you drill in the firewall?
The ball on those is aluminum. Do they make a stainless version?
A fella can weld up a tubular steel pass through for about fifty cents. Point it at any angle you wish.
http://www.vansairforce.com/community/showthread.php?t=72087
See post #38, 40, and 42.
Are those pass throughs of yours 2 pieces? A welded tube section then a backing plate to sandwich the firewall between them?
Thanks for the examples guys. Looks like I'll have a buddy of mine weld me up a few of these. What do you recommend for the thickness?
