things I would do differently, and would do the same
Hi Joe,
The scat is 3.5" -- I figured I would split the difference. There is a butterfly valve (like a throttle plate) mounted in the flange on the back of the #3 baffle -- you can just see the pivot nut, and the control cable going up to the far side in the picture.
How does it work? First, I have the IO-360-A1A angle-valve engine with piston squirters, so there is more heat load put into the oil.
The temp control works great. In the winter, cruising, I have it about 2/3 closed. In the summer, it is wide open all the time. On a warm day, it will cruise with oil temp about 175F--180F.
On hot days, like 95F on the ground, If I take off and climb straight to 10.5K at 115 kts, the oil will get to about 220F. This summer I made a fuel stop in Wells, NV in the mid afternoon. It was almost 100F on the ground, field elevation 5700. The oil was already hot from cruising for 3 hrs. I climbed at 125 kt straight to 12.5K and the oil reached 230F. That's the hottest I've ever seen it. 15 minutes of cruising and it was back to 195F.
To do over again, I think I would use 4" scat. The 3.5" has only a little more flow area than the cooler, so I am getting some pressure loss. Some people think the angled plenum is bad, but the flow is slow in there, and there is very little pressure loss -- the wedge shape helps force uniform flow through the cooler (it can't just all pile up at the end).
I also notice that the way the Niagra cooler is made, there is some leakage out the sides, so some flow escapes without going through the cooler. I want to seal that up.
All and all, I am very happy with it and would do it again. If there was a place that it could be located where the engine mount tubes would not interfere, it would be cool to put a fiberglass diffuser on the exit to slow the flow down, this would increase the flow velocity through the cooler. But my firewall was already full of other things, so this is where it needed to go.
Oh, and say hi to Bruce Patton for me - a new neighbor of yours
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
