7DeltaLima
Anyone used the VA-186 oil cooler box that is used for the firewall mount of the oil cooler in the -10 on the 7A. I'm going to move the oil cooler off the baffles on the 7A and onto the firewall. I've got 750 hrs on the 7A and this is the second time that the baffle has cracked so I'm going to move it. The engine is a IO360A1B6 and tends to kick out a little more heat and I'm using a larger than std oil cooler so don't think the baffle is ever going to hold up for the long term.
Anyway, I'm building a -10 and working on the baffles and it looks like this oil cooler mount would be a good alternative to fabricating something for the 7A. I can look/measure the 7A in the next day or two but thought if anyone's already "been-there-done-that" and it worked, I'll order the parts and make the change asap.
If anyone's done this, did you also need a longer oil line... The -10 fwf kit has a VA-190 27inch line...
Doug
Doug
