LettersFromFlyoverCountry
Does anyone have the DWG number for the firewall layout for the RV-7A (not DWG 19).
I got a stack of plans for FF from Van's and while it has a really nice DWG for the Rv-8 included (OP-34), which tells me EXACTLY where the transducer manifold is mounted, there is nothing to so indicate on an RV-7/7A. OP-32 has a drawing showing where the AN833-6D bulkhead fitting location is (the same with OP-28 on a carbureted engine) and by it I can kind of guess where to mount it -- just by counting along the rivet line in the drawing (and I assume the hardware is the same as the RV-8 drawing), but it's odd that there isn't a specific location called out on the plans I have.
Also, it would be really cool if someone would put together an index of all the OP drawings Van's has available. Or maybe someone already has.
