BGordon
Good morning everyone,
Working on my fuel line from the boost pump to the firewall and have a quick question. When I started my project I intended to use a carbureted engine so I installed the F-601Z aux fuel firewall doubler. I ended up getting a fuel injected engine so my boost pump location changed. My question is, would there be a problem with running a steel fitting through the aluminum doubler? Or do I need to go through the firewall at a different location?
Brandon
Brandon
