OK...page 31-05 has you clock the fitting at 20-deg from horizontal and apply sealant which I would assume will glue it in place. Then page 31-11 says clock it 5-deg from vertical (for a taildragger). My public school math sez this don't add up too good. Don't see anything in the gotchas list. Which is it?
Sort of related - would high-temp RTV be an acceptable substitute for this fitting and also the brake line firewall fittings as well? I have both RTV and tank sealant but only one requires me to mix up a batch.
