Rob Erdos
I bought a partially-completed RV-6 project last year. I don't want to admit how many hours I have spent staring at it and reviewing the plans. Getting into a project in the middle is quite intimidating for a newbie. It's essentally a completed airframe, awaiting engine and systems.
I bought an engine (Mattituck TMXIO-320) and the appropriate Firewall Forward kit from Vans. A sensible plan for attacking the firewall would seem as follows:
Before hanging the engine...
*** battery box
*** cabin heat valve
*** oil sensor line along firewall
*** doublers (fuel line, starter solenoid)
*** brake reservoir
After the engine is in place...
*** gascolator (fuel injected engine, but mandatory in Canada)
*** sensor manifold
*** starter solenoid
*** battery master relay
*** oil breather line
*** electrical/sensor pass-through
*** throttle and mixture controls
*** battery cable
*** cabin heat control
*** fuel line
Does that make sense? Are there any other items that MUST/SHOULD be installed on the firewall before I hang the engine? Opinions most appreciated.
Rob
*** battery box
*** brake reservoir
*** sensor manifold
*** battery cable
*** fuel line
Rob
