Hang the engine.
Bolt on the prop. (Or something of the same size.)
Fit the cowl xtop and bottom.
Fit the carb or fuel servo
Fit the FAB
Fit the baffles. If you have a snoutless bottom cowl, install these before fitting the FAB.
Install exhaust (don't tighten the nuts because you will take it on and off a few times. Finger tight is good.)
Wire, plumb, etc. The er engine.
Install exhaust for the final time and torque the nuts
That should give you an idea of the sequence.
