On the firewall the two F-601J angles you that you fabricate are show non the plans 3/32 of an inch above the bottom F-601M-1 angles top face. Well I somehow missed this and drilled mine setting on the F601M-1 angle. I have room to remove 3/32 of an inch but then I am afraid I will come up short on the top side later. Anyone have any input on this? I will probably just remake the F-601J but thought I would see if anyone had any other suggestions. Does sometign go in the 3/32 gap later or is it just clearance built in for some other reason?
I think waht got me was the fact they had you round the edge of the F-601J pieces to fit the inside radius of the F-601M-1. Why do that and then set it 3/32 inch above it?
