Smilin' Jack
I have seen several different types of firewall eyeball assemblies for the throttle, prop and mixture cables to run through. I like the Aluminum single cable design that requires a 3/4 inch hole in the firewall but what size do you need for the internal hole that the cable actually goes through. Do you have a part number? what is the diameter of the cables?
The item is located in the spruce catalog on Pg 145 and is model number TTP in the column to the right.
Smilin' Jack
Smilin' Jack
