jwheeler313
Active Member
Do I need to use products such as 3M Fire Barrier 2000+ when I install doublers on the firewall? If so, do I put it all over the doubler, rivet holes, or only where items pass through? An example is the doubler plate used for the brake line bulkhead fittings on the 7 I am building.
