First post here goes:
Are there any special considerations when mounting a firewall doubler on the engine side of the firewall?
I want to make one large doubler for the MGL RDAC which will also be mounted on the engine side. Doing this will allow me to fix the doubler to one of the stiffeners.
If I make a doubler for the inside I will have to split it intwo smaller ones because of the stiffener running through them. Will also be less sturdy because I won't be able to easily connect to the stiffener.
Regards
P.
Regards
P.
