The manual states: "Draw a fastener line on the upper surface of the trailing edge wedge 7/32" to 1/4" aft the forward edge."
What does VANS understand as "forward edge"? The first line I draw resulted in the wedge being pushed against the stiffeners in the middle. The second "forward edge"
results that the wedge sticks out for about 4/32" at the trailing edge.
I tried to find some pictures from other builders but they generally don't give enough detail to confirm that this is the correct way.
