Finishing Plugs and Caps
DHeal
Patron
If you want to fill those somewhat unsightly tooling holes on your RV-12's wing tip bows and stab end ribs, you might want to use the following finishing caps:
-- Hillman Arrow Clips - Nylon (White) #394150-C (for the 3/16" holes)
-- Hillman Arrow Clips - Nylon (White) #394148-A (for the 1/8" holes)
I found these at my local ACE Hardware store.
To seal-up the ends of the foot steps, I used the following plastic end-plugs:
-- Hillman Round Cap Plugs (Black) 3/4"
I found these at LOWE's.
http://imgur.com/cvypRxR
http://imgur.com/sfrHrIh
Your picture link isn't working.
When I tried to put plugs in the end of my steps, they kept blowing off in flight. I may try these again if they'll stay put.
Randy -- I think the photos should work now. Three of the step plugs have stayed in place for 300+ hours without glue. I added a touch of contact cement to the left forward step plug since it would occasionally ease out a bit due to my foot hitting it. -- David
Bumping another old thread.
There's a great glue called "Amazing Goop" which I believe used to be called "Shoe Goo" when I was younger (same product as far as I'm concerned) but it's a rubber based glue that holds with the power of epoxy, but has a little give like that of stiff rubber.
I Q-tip and a dab of gas or toluene easily undoes anything glued with this glue, so it's only for non-solvent parts or areas.
Amazing Goop is just that! It's an incredible glue. It does shrink a little when applied thickly.
