Finishing Kit parts list
cnpeters
Anyone have a finishing kit parts list they can scan or mail a copy to me? I'm having difficulty getting this from Van's despite even telling them my desired configurations (tip up, IO-360-B2B, Catto 3 blade fp, etc). A list for a tip up configuration would be most helpful.
Thank you,
Carl
Me to Please
Reiley, would you mind sending it to me as well. [email protected]
RV7 tipup.
I have called Vans all last week, they are too short manned with the weather.
Thanks in advance
I just emailed a copy of my excel sheet to Bugsy and JA. IO-360 with quadrant throttle, tipup. Anyone else send me a pm and I'll be happy to forward my list.
greg
Thanks guys you rock
Thanks again.
With all the snow piling up at Vans Im sure they appreciate not having to pester with this.
Have a Merry Xmas and Happy new year.
If someone has one for a 9A slider I'd appreciate getting a copy. pilotandy (at) gmail.com
When I called a few weeks back they said changes can be made after the order has been placed, so I may end up just sending in the order vanilla for now.
Thanks to all of you, too. I got the same message from Van's this past week -send in the order, and then you can amend it. However, I want to see the actual parts list and compare to aftermarket products (eg Grove's nose gear) - I have many deletions, enough that I may just order piecemeal. Even though I told them all the configurations, they don't seem to be too accomodating for now.
9A slider list?
I'm looking for a 9A slider Finishing kit list too. If anyone has one my email is
dave dot gribble at mchsi dot com
thanks!
I'm going to bump this thread.
Looking for a copy of the finish kit contents for a tip up 9A.
Probably will go with an IO-320 and fixed pitch prop, but I'm still deciding...
Any other recommendations on items to purchase from Van's along with the finish kit?
Thanks in advance!
Take a powder for a sec.
Fella's,
I think you might be beating up Vans over the wrong kit.
There is precious little in the finish kits that is subject to common customization.
Once you tell them the engine and prop, it is what it is. Not much left open to easily change.
I can think of only a couple of items.
Brake hoses (If you are Bonaco bound)
Nose Wheel (if you want a Grove or something)
Cowl (if you are doing a holy cowl)
The majority of the rest of the finish kit is the canopy, engine mount and gear fairings. Its not stuff you are going to obtain easily elsewhere.
The firewall forward kit, on the other hand, has many commercially available items and is one that could be scrounged and scrutinized a lot.
A list of the hardware bags would be nice to have. I don't need any more rivets! I still have unopened bags from the fuselage and wing kits... :p
I have bought a couple of items already from Van's that are needed and I don't know if these are provided in the finish kit. Deleting these items and adding other things I'll eventually need will save me shipping costs and time later.
So, if any builders can shoot me a scanned copy of the finish kit contents, I would be grateful. Otherwise, I'll bug Van's.
Looking for a 7 slider as well, I am contemplating ordering the engine mount and gear/wheel assemblies seperatly so I can get the fuse rolling around and easily movable sooner. So if someone has one they can email me I am interested to see what all else is included besides the obvious, cowls and canopy with frame. Thanks alot!!
David
Flyguytki at gmail dot com
Finish Kit List!
Here is the information from Van's on the finish kit contents.
1.00 RV-9A FINISH TIP-UP =========KIT========
1.00 9A FIN HARDWARE -------SUB-KIT-------
1.00 BAG 1985 K1000-08/K1100-08
1.00 BAG 1986 MS21053-L08/AN507C832
1.00 BAG 1987 AN507C632R8/AN509-8R8
1.00 BAG 1988-1 AN3/4 BOLTS/MISC HWR
1.00 BAG 1952 AN426AD3-3.5
1.00 BAG 403 AN426AD3-4
1.00 BAG 1916 AN426AD3-4.5
1.00 BAG 1934 AN426AD3-5
1.00 BAG 1935 AN426AD3-6
1.00 BAG 807 AN426AD4-5
1.00 BAG 1906 AN426AD4-6
1.00 BAG 1979 AN470AD4-4
1.00 BAG 1983 RIVETS AACQ4-4/MSP42
1.00 BAG 1984 K1000-06/AN507-6R8
1.00 BAG 1989 NOSE GEAR HARDWARE
1.00 BAG 1996 AN365/AN310 NUTS
1.00 BAG 1997-1 WASHERS/COTTER PINS
1.00 BAG 610 MAP BOX HARDWARE
0.00 ZZZZZZZ EOK ZZZZZZZ -----END OF KIT------
1.00 9A FINISH COMMON ------SUB KIT--------
1.00 AS3-016X5X6 ALUM SHEET
1.00 AT6-058X3/8X4 ALUM TUBE (INCHES)
1.00 9/9A PLANS FINISH SET PLANS AND MANUAL
1.00 C-601-1 SXS CANOPY 76%
2.00 F-994A EMP GAP COVER
1.00 F-994B EMP FAIRING
2.00 F-999 WING ROOT FAIRING RV9
1.00 RUBBER CHANNEL X 4' EMP FAIRING SEAL
1.00 RUBBER CHANNEL X 12' WING ROOT SEAL
2.00 VA-118-1 BRAKE HOSE ASSY 28.5
1.00 AS3-063X4 1/2X10 ALUM SHEET F-303E
2.00 VA-106 MAIN GEAR AXLE NUT
1.00 WHL FAIRING, PRROD 9A ------SUB KIT--------
2.00 VA-157A-1 WHL.PANT FRONT EPOXY
2.00 VA-157B-1 WHL.PANT REAR EPOXY
2.00 U-808 SYM.WHL.FRNG.BRKT.ALL
1.00 U-810-L SYM.WHL.FRNG.BRKT.RRD
1.00 U-810-R SYM.WHL.FRNG.BRKT.RRD
1.00 DWG C-2 MAIN WHL FAIRING INST
1.00 GEAR LEG FAIRING ROD -------SUB-KIT-------
2.00 U-817 GLASS LEG FAIRING RND
2.00 HINGE PIANO 063X3' LEG FAIRING HINGE ALL
1.00 BAG 871 AN426AD3-4 RIVETS
1.00 DWG C-3 MAIN GEAR LEG FAIRING
1.00 9/9A FIN TIPUP UNIQUE ------SUB KIT--------
1.00 RUBBER CHNL S88D20X60 60" RUBBER SMOKE SEAL
2.00 AS3-032X3X29 ALUM SHEET C-603
1.00 C-607 LATCH HANDLE
2.00 C-613 SPLICE PLATE
1.00 C-614 SPLICE PLATE
1.00 AB4-250X1 1/2X9 TOTAL AL BAR MAKES 2/C-619
1.00 ST4130-035X3/8X5 3/4 STEEL TUBE C-621
1.00 ST4130-035X3/8X9 STEEL TUBE C-622
1.00 C-704 TIP-UP CANOPY PLATE
1.00 AT6-058X5/16X18 ALUM TUBE
1.00 AA6-063X3/4X3/4X18 AL ANGL C-612/C-712
2.00 AB3-5/8X1 1/4X4 ALUM BAR C-723
1.00 F-697 CHANNEL
1.00 WD-620-PC CANOPY RELEASE HANDLE
1.00 WD-621-PC CANOPY HANDLE
1.00 WD-725-L CANOPY SIDE RAIL
1.00 WD-725-R CANOPY SIDE RAIL
1.00 6/6A TIP-UP STRUT CANOPY STRUT KIT
1.00 C-702 TIP-UP CANOPY SKIN
1.00 WD-617-PC CANOPY LATCH
1.00 WD-716 TIPUP CANOPY FRAME
1.00 CANOPY BRACE TIP-UP 6,7,9 REINFORCE KIT
1.00 "P" STRIP X 50 SELF ADH RUBBER STRIP
1.00 9/9A FIN HDWRE TIP-UP -------SUB-KIT-------
1.00 BAG 911-1 TIP UP CANOPY HW
1.00 BAG 1978 AN470AD4-5
1.00 BAG 903 CS4-4
1.00 BAG 1998 K1000-3/AN509-10R18
1.00 BAG 1999-3 MISC. AN3 BOLTS
1.00 BAG 2000-1 NUTS/WASHERS MISC.
1.00 BAG 2001-4 MISC. HDWRE TIP-UP
1.00 WHL INSTL KIT TRIGEAR WHEEL INSTALL KIT 9A
1.00 U NW501.25 NOSE WHEEL W/BEARINGS
2.00 U-623-1 AXLE BRNG.ADPT. MATCO
1.00 U CLEVELAND 199-10200 WHEELS & BRAKES 5" *
4.00 U-405 AXLE SPACER
1.00 U LAMB TIRE NOSE WHEEL 11X4.00-5
2.00 U LAMB TUBE NOSE WHEEL TUBE
2.00 U 5:00X5-6 6 PLY TIRE MAIN GEAR
2.00 U 5:00X5-6IT TUBE FOR 5:005-6
2.00 U-611 DISC SPRING
1.00 GEAR LEG FAIRING NOSE -------SUB-KIT-------
1.00 U-818 GEAR LEG FAIRING NOSE
1.00 HINGE PIANO 063X3' LEG FAIRING HINGE ALL
1.00 DWG C-1 NSE WHL, GEAR FAIRING
1.00 WHL FAIRING, NOSE 9A ------SUB KIT--------
1.00 U-813A-1 REAR NOSE WHEEL PANT
1.00 U-813B-1 FRONT NOSE WHEEL PANT
1.00 U-713C-L NOSE WHEEL PANT BRCKT
1.00 U-713C-R NOSE WHEEL PANT BRCKT
1.00 BAG 933 ALL 'A' MODEL HDWRE
1.00 SPINNER, FP-13 SEN SENSENICH METAL PROP
1.00 S-601-1 FG SPINNER BOWL 13"
1.00 S-602-1 FP,CS,SEN 13"BACK PLT
1.00 S-605 SEN SENSENICH FRONT PLATE
1.00 BAG 913 FP SPINNER HW
1.00 BAG 961 AREA WASHERS
1.00 BAG 945 ADDED SPINNER HWDRE
1.00 DOC SPINNER DWG C4 & CONTENTS
1.00 9A COWL KIT 0-320 -------SUB-KIT-------
1.00 BAG 1953 AN426AD3-4
1.00 BAG 1954 AN426AD3-4.5
1.00 COWL,6/6A BOT. 0-320 BOTTOM COWL PRE-PREG
1.00 COWL, 6/6A TOP C/S-1 PRE-PREG.TOP COWL
1.00 COWL, 6/6A INLT.LFT-1 PRE-PREG.INLET LEFT
1.00 COWL, 6/6A INLT.RHT-1 PRE-PREG.INLET RIGHT
1.00 COWL, 6/6A OIL DOOR PRE-PREG OIL DOOR 7,9
1.00 AN257-P3X6' HINGE X 6'
1.00 U-720A UPR.AIR OUTLET BRACE
1.00 U-720B LWR.AIR OUTLET BRACE
1.00 U-620B BRACE
1.00 AS3-063X2 3/8X6 1/2 ALUM SHEET U-621
1.00 AS3-032X1 1/4X7 ALUM SHEET U-620D
1.00 AS3-063X1 5/16X7 ALUM STRIP U-620C
2.00 SSP-090X6' STAINLESS STEEL PIN
2.00 SSP-120X6' STAINLESS STEEL PIN
1.00 HINGE PIANO 1/8X9' ML
1.00 BAG 923-1 COWL HDWRE
1.00 9A DYNA-1KIT 0-320 -------SUB-KIT-------
1.00 WD-630-1 NOSE FORK *
1.00 WD-631-PC NOSE STOP FLANGE *
1.00 WD-739-PC 6/7/9A D1 ENG MNT *
1.00 U-603-3-PC NOSE GEAR STRUT *
1.00 BAG 917-1 ENG/LG HW (6A,7A,9A)
1.00 MS21025-20 NOSE GEAR AXLE NUT
but what about....
when I try to look some of this stuff up in "the list" on van's site, much of the stuff does not come up.
Try for yourself with say... brakes or wheels.
I'm looking for prices too. Maybe this will be better suited to another thread-- moderators take note.
