DonFromTX
My largest time waster in building this kit, is just looking for the right part. Oh yeah, I have the bags all cross indexed, when the instructions call for a certain bolt screw or nutplate, I know exactly which bag it is in, and where that bag is located. However, when I open the bag, there are for instance maybe 5 different nutplates in the bag. None have the number stamped on it that is called out in the plans however! What I have taken to doing, is to go forward in the plans, try to identify what screws into that nutplate, then choose one that fits that bolt or screw. Sometimes that is not an option, as there are now 6 different bolts in the bag, I must guess which one to use..
I have not found so far a definitive chart that lists all AN hardware with a key to real world sizes, just partial charts with some information on various hardware. I am sure I used to have one of those.
A good example is on page 10-03, figure 2. Clearly calls for six screws, numbered AN526-632R8. Problem is, there are no such screws in the kit, but there IS one close, a AN526 C 632R8. I looked for hours to find the significance of the C as a substitute, no luck with that. I finally just used the "C" screws considering it was "close enough" for airplane work. I don't like "close enough" specs for this project. Has anyone found a real good chart to identify AN hardware, I am wasting hours on this problem alone?
