Final rigging of control surfaces - strange issue
MS19087
So all control surfaces are mounted. Trying to rig ailerons for neutral position with sticks perfectly neutral as well. I set these with elevator also neutral. Having achieved this excellent alignment at neutral position a very strange thing happens and I need to know if this is normal. From neutral position, if I push or pull the stick to move elevator from neutral the ailerons move slightly! It is as if applying elevator also slightly affects aileron movement. Now this is while I have two guys holding the ailerons in neutral position to insure that I'm not putting left or right input. Is this normal? Comments please before this drives me nuts?? Thanks
