EJWash
Active Member
Hi All,
Working on my -14 vertical stab. Before permanent installation, there is one hole in each of the six rudder hinge brackets that are final-drilled to #12. Of course, doing so removes the powder coating inside the hole. So, the question is: Is anything applied to the inside of the hole after removing powder coating/paint to stave-off rust/corrosion? What practices are out there?
Thanks in advance.
Thanks in advance.
