Filtered Airbox - Vertical Draft For 0320. $180.00 plus UPS.
superpitts I'm New Here Oct 11, 2021 #1 Filtered Airbox - Vertical Draft For 0320. $180.00 plus UPS. Attachments 80819FE8-9EB5-4DC2-AB1E-275561A32542.jpg 495.6 KB · Views: 134
gmcjetpilot Well Known Member Oct 11, 2021 #2 Needs to be moved to Classified... It is missing some parts, the K&N filter, base plate, nut plates, fastener alternate-air/carb-heat hinge/bracket/rivets, bypass valve (optional goes on bottom). Last edited: Oct 11, 2021
