I am ready for a filler primer to be applied on the windshield fairing and some other areas of fiberglass buildup around the door frame. Any recommendations favoring a specific product? How are these applied - brush, roller, spray?
Bob, you're gonna get a lot of different opinions. Walk around enough fly-ins looking at unpainted RV's, and you'll see that quite a few builders tried every magic filler product on the market.
Ok, here's the conservative approach. Microballoons and epoxy are mixed to a firm paste and squeegeed on as necessary, then sanded for contour. The surface is sealed with a skim coat of straight epoxy to fill the pinholes, then sanded dull without breaking through. Epoxy primer is followed by high build primer, both from the same manufacturer's approved system.
Contouring with micro; pencil marks highlight low spots, which will be filled/sanded again. Just scribble with an ordinary #2, then block sand. The pencil marks sand off the highs and remain in the low spots.
Countoured part being sealed with an epoxy skim coat. A few years back I started rolling the wet squeegeed surface with a cheap nappy roller, as it eliminates all the squeegee marks. It also leaves a nice "orange peel" sort of finish on the epoxy, which makes it easy to sand slick without breaking through...you can easily see how much you've cut.
Looks like this before cure and sanding:
Last, shoot with epoxy primer. Countouring was good enough to make a high-build primer unnecessary.
At this point I just add the same primer I'm using for top coat (PPG DP-40LF). For the next plane I'll use PPG K36 high fill primer, wet sand and then do the DP-40LF on top of that when ready to do final paint.
Hi Carl. For maximum adhesion of K36 (and subsequent top coats) on a composite surface, shoot DPLF epoxy primer, then K36 as soon as the solvent flashes off. The PPG field rep's actual words were "...as soon as you can clean and reload the gun".
You
can shoot more DPLF over block-sanded K36 prior to topcoats, but it's not strictly necessary. I don't because a
sprayed surface finish isn't likely to be as slick as a block-sanded surface...and imperfection will show through the topcoat.
