I have fitted the elevator tips and clecoed in place. I still need to final shape but am concerned about too much sanding. If you look at the attached picture you will see that it is a little long. If I sand it all the way to match the elevator, I believe it will sand the tip open. The way the piece is made is with two sheets of glass that meet in the area. A little forward the sheets spread apart as the tip tapers open. Sanding this much off will probably open up the end. Also I doubt that I can get the end as thin as the elevator trailing edge. What has everyone else done here.
[/IMG]
![bi6j3m.jpg](/proxy.php?image=http%3A%2F%2F%5BIMG%5Dhttp%3A%2F%2Fi44.tinypic.com%2Fbi6j3m.jpg&hash=119b647fd144424caa52195177eb38ee)
