It works fine. It tends to cure with a bit of pourosity which can interfere with the primer coat so once I have the desired countour I apply pure epoxy to it, hit it with a heat gun to warm it (a bit just to make it runny) then I wipe it off. It fills the voids and gives you a tougher surface with minimal weight gain.
