Charles in SC
I have a -7 slider. I am working on the fiberglass piece around the windshield.
I have it in pretty good shape but how do I know when to give up? I have been putting a layer of thick micro and then sanding to try to get it even (waveless). I do not know if I am getting it smoother or just creating a different set of waves with each layer.
At some point should I use body filler which I have found to be a little more workable and smooth sanding? The waves are probably no more than a few thousandths but I cannot seem to get rid of them all at once. There are so many different curves on this piece I have not found a good way to use a sanding block on it.
Another question.
Should I paint the fiberglass after I decide it is finished to protect it before the plane is flown and painted and if so, what with? Primer? What type?
Thanks in advance!
Another question.
Thanks in advance!
