Designing this for an IFR RV-10 with SDS EFI.
I started off with Nuckoll's Z-101 design combined with Leok's diagram I found on VAF. I had initially intended to go with dual alt and 1 battery and adapted the Z-101 design to this:
But it looked like however unlikely it may be, a battery failure would result in the alternator keeping everything online, and while it should be more than capable of the task, if the alternator had a hiccup or something like that there is no way to bring the backup or primary alternator back online.
So I moved on to adapt the design I had into a dual battery dual alt design like this:
This should allow the engine electronics to remain powered no matter battery or alternator failure, and also provides a way to energize the backup alt in the scenario of a VP-X failure. I moved everything off of the E-bus in the second design as I intend to use an ETX900 as the primary and an ETX680 as the secondary, so either should have enough capacity to keep the main bus fed for 20-30 minutes and I can leisurely shed load through the VP-X if I need to.
One thing that I need to add to these diagrams is diodes on the two backup alternator field wires.
Interested in any feedback or suggestions.
![1altdualbatt_liiceg.jpg](/proxy.php?image=https%3A%2F%2Fres.cloudinary.com%2Fdimxyge4j%2Fimage%2Fupload%2Fw_1000%2Cf_auto%2Cq_auto%2F1altdualbatt_liiceg.jpg&hash=546c81bb0b83a076a7c37f6440e6beba)
![dualaltdualbatt_mf8gzz.jpg](/proxy.php?image=https%3A%2F%2Fres.cloudinary.com%2Fdimxyge4j%2Fimage%2Fupload%2Fw_1000%2Cf_auto%2Cq_auto%2Fdualaltdualbatt_mf8gzz.jpg&hash=36d2d8da6aec26da5efa5e94557fd531)
