Hello all, fresh dynon install.
Had a static feedback from I'm assuming ground when landing lights are on.
They're just cheap 2x2 flush mount LEDS.
Am I able to correct this by changing ground or am I forced to replace?
I've also had good luck with Squadron Pros - no noise.The power supplies in inexpensive LED lights can be very noisy, this is well -documented with several attempts to use cheap LED landing lights. I installed some "Amazon" lights in my RV-6, the price was right, they looked fantastic, but they made the COM unusable. The "aviation" LED lights use a "quiet" power supply.
