az_gila
Could any of the APRS experts look at my tracks (N12GA) and hazard a guess at what's going on?
I'm out travelling, and the July 1/2 tracks across AZ, NM - a stop at Amarillo - and on to Springfield, MO worked reasonable well.
Then no track from Springfield to Burlington, IA....![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Then only one "hit" on the trip from Burlington to Sioux City, IA which was right in the middle of the Des Moines Class C.
No hits from Sioux City to Rapid City, SD.
Then on the next trip from Rapid City to Ft. Collins, CO, again, only one hit, this time on final at 400 ft into KFNL.
Could an expert look at the raw data, and see if anything is obivious? I know my antenna isn't the finest, but it worked initially.
I have a MicroTrak 300 with the Byonics power supply module and a byonics GPS2 reciever. I have an LED on the 12 v supply and that appears OK.
The LEDS on the card indicate good GPS track, and a "blip" every 2 minutes.
I'm guessing a bad antenna wire, but confused I don't get more hits when flying higher.... Perhaps I got my programming screwed up, or it "re-programmed" itself....
gil A - on the road... KE6HAP
