Hey guys I have a question about fastback kits for 8a's. I have never seen a picture of an "a" model converted to a fastback. Is that because they don't make them or does it not look right on the "a"? Also I have heard that the fastback kit adds some more shoulder room up front. Is that fact or fiction? Showplanes sells the kit for $2500.00, is this a good deal or not? I am a big dude so I am looking for ways to free up some room. I have done everything humanly possible to lose weight short of exercising and dieting
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
As was stated above, there is an "A" under const at Show Planes. Seems to look just fine.
The extra room comes from the fact the canopy tips over to the right, and there are no tracks for it to slide back on. The tracks must be parallel, and as the fuse is narrower at the rear, the rails at the front must be the same.
The Show Planes kit includes new side rails, they are an inch or so narrower than stock, and it looks like they could be trimmed back even more
with proper attention to structural integrity.
Like you, I am a big guy, and have found that the shoulder room in a stock 8 is very cramped when I have my arms down, kinda like you would need to do if you wanted to use the throttle, and control stick. Otherwise, no problem. I sat in a Show Planes tip over setup, and found the increase in shoulder room to be quite good.
Another couple of things------the viability forward is improved, and the access to the instrument panel is better.
And-----ventilation----the canopy latch has a position that keeps it open an inch or two, for when you are on the ground and the greenhouse is getting hot. On a stock setup, the front part of the canopy blocks the cool breeze.
The tip over canopy, and the raised turtle deck (fastback) work together, I dont think you can do one without the other.
Needless to say, I am impressed with the product, and plan on using one on the 8 I hope to build someday.
