Rick_A
I had an avionics shop do my first P/S test today and it failed big time. I had a huge leak in the static system at the "T" where the static ports join together and transition to semi-rigid line. I'm using Vans static system for this portion of the system.
The big problem at the "T" was that one of the connections had come completely off the T and I had not noticed. I suspect the other one was leaking too.
So my first question is: Vans system uses very small (I think it's 1/8" ID) tubing off the pop rivit static ports. What's the best way to "T" these together and then connect to the hard nylon tubing that runs forward?
Second question. I observed that when I got my Altimeter back from it's calibration test that the avionics shop put teflon tape on the on the static port fitting. I did not use teflon tape on any of the nylon fittings that I installed. Is this standard practice and should I remove and reinstall the fitting to all my instruments and AHRS using teflon tape?
