My Factory Visit
I picked up my wing kit at Vans Monday and took the factory tour with Ken! I also saw both the original and final RV12 (the tail is finalized). The computer driven stampers are pretty neat. I will probably make another run to Vans for a test flight in the future. As it was I spent the whole day driving to and from Aurora. I transported the two boxes on a flat trailer that I use for white water rafts. The only problem was the roller on the back of the trailer. The folks at Vans were real helpful and put little blocks under the spar box to clear the roller. They also suggested that I modify my tie down procedure to include a "wrap" around the spar box. I did buy a couple of RV coffee mugs
?s
As I understand it, most of the rivet holes are punched out and these do not need de-burring. The edges of the parts may benefit from a very quick pass over a scotch brite wheel. According to the plans I should prime the the aluminum bar, angle and tube. Vans uses P60G2 and, surprisingly, I found a gallon of this primer and catalyst locally. I cleaned out my wooden tool shed and plan to line the walls with plastic and use a HVLP gun to spray the parts leaving the doors open, taking a break if I see a build up of overspray. I did buy all the protection gear including a charcoal respirator, but I did not buy an explosion resistant fan. Without stirring up too much controversy, does this all sound reasonable? I am excited to get going.
Thanks for your thoughts,
Jeff
?s
Jeff
