As long as you are building EAB. I don't think the ends would justify the means though. Truthfully, it took me a while to get the heavy wing sorted out as I was flying with a tab on my left flaperon. That was until I got off my lazy behind and figured out why I needed a tab, yet most others did not. Now that my 12 is properly rigged, I never even think about it. Regarding the rudder trim, most, including me, use a tab on the rudder. You will use your right foot on take-off just like most other light singles. IMO, you would be adding a lot of complexity to what was designed as a simple airplane. JMO.
