tx_jayhawk
Would anyone be able to measure the mounting distance between the center of the mounting holes on the Facet (carb) fuel pump? It appears my pump flanges are about 2 9/16" center to center. Given Vans built my QB fuse with a 2 3/8" center to center dimension on the doubler plate, it seems I have a problem. It looks like a screw-up on the QB mounting, but I want to make sure I don't have a bad fuel pump.
Has anyone else had this problem with the fuel pump mounting? The misalignment appears great enough that I can't just enlarge the mounting holes on the fuel pump. Given the doubler and nutplates are already drilled and riveted to the firewall, there doesn't immediately seem like a clean solution.
Scott
7A Finishing
Scott
7A Finishing
