Facet cube upgrade
Eddie
Member
So my facet cube pump is done after 18years and 1300 hours. I am not able to get the same replacement model locally, but see that they have the new Posi-Flow range of pumps. From the website is seems to be an upgrade on the old cube and is nit as noisy. Does anyone have more experience with this new pump? My application is an O-360.
Hi Gary
Thank you for your reply, but I'm in South Africa so ordering from van's isn't that quick and easy.
Our local auto shops stock the posi-flow range and i'm wondering if anyone knows if it will work. The part number that seems to match is the posi-flow 60106.
