Pilottonny
I am currently installing the Filtered Air Box. I was wondering how difficult it will be to get the cowling on and off with the BAF-Seal that will be riveted to the FAB-Snout and needs to wrap around the Cowling inlet. Also I see no reason to have the top (straight) part shortened, as is mentioned in the plans, because the cowling will just butt up against that. The problem is in the seal that have to wrap around the sides and bottom.
If the sides and bottom seals would be riveted to the cowling inlet, instead of to the FAB-snout, removal and installation of the cowling will be a lot easier, I guess. Has anybody done this?
What about those pop-rivets, do you all have these sticking into the inside of the FAB-snout?
Regards, Tonny.
Regards, Tonny.
