Funguy
I have a new Filtered air box to construct and add to an O-320. I'm having a problem seeing how this goes together despite looking at some other builder logs. In particular, the fiberglass housing is about 3.5? deep. The filter is 2.5" deep. The aluminum top plate is about 0.5" deep and recesses into the fiberglass housing. If I press the top plate onto the filter into the housing, the top edge of the top plate is about 0.5" below the top of the fiberglass housing which just does not look right and does not look like others that I see in builder logs. Other builders seem to have the top of the housing aligned more or less with the top of the top plate. What am I missing here?
Thanks in advance!
Cheers, Sean
Thanks in advance!
Cheers, Sean
