Just wondering what orientation people used these bolts that run through the F904 rear center bulkhead and into the tops and bottoms of the F916 seat ribs. The plans view shows them with the bolt head aft, against the rib flange, however the note next to it states that it is acceptable for the bolt threads to bear against the rib flange, which would imply the opposite orientation. Also, I know that bolts generally are faced aft when possible, so this makes more sense. If there is any chance of bolt threads bearing on something, I'd rather have it be the rib flange, so I oriented them front to back. May be a little harder to set the rivets right belowthe nut, but not impossible. Anything I'm missing?
And while I'm thinking about it, same question goes for the bolts that attach the control column mounts to the bulkhead. I did mine as illustrated, with the bolt head on the mount, washer/nut on the bulkhead.
Chris
Chris
