All,
I am having trouble figuring out the orientation for the F805E rudder cable support. DWG25 section G-G shows the 805E mounted to the aft side of F805B. However, also shown on the aft side is K1000-08 platenut. The directions say the 805E is mounted with a single 8R8 screw. However, there are holes in the 805E for the rivets that will hold the platenut in place. So, I am all confused.
A) does the 805E rudder cable support need to be removeable and thus should only be secured with the screw? If so, why the holes for the platenut?
B) If it is only to be secured by the screw, I assume the platenut is best mounted on the aft side of 805B and the 805E support on the forward side of 805B. Although, it probably doesn't really matter much.
Thanks for any assistance.
