Fearless
I was working on the F705 Bulkhead last night and gotten myself into a problem. The exploded view (drawing 20) doesn't show a matching rivet hole on the F605C doubler beside where the seat belt brackets are but the Front View Assembly drawing has you countersinking the rivet (4-8) position going through the F605C doubler and the F705B center section bar and the F705A rear spar attach bulkhead - where the first bend is on the doubler. I countersunk the center section bar at that location and have already riveted on the center section bar and rear spar attach bulkhead. I haven't riveted on the doublers to the center section and spar attach bulkhead yet.
I really would rather not have to take the pieces back apart and buy another center section stock. Will it be okay if I don't rivet through the doubler at this particular spot. And if that isn't okay would it be acceptable to put some JB Weld into the countersink on the center section and drill it back to a #30 and then countersink that rivet postion on the doubler and then rivet the doubler, center section and bulkhead together?
Looking for some feedback ,
